72' K5 front axle replacement
Discussion in 'OffRoad Design' started by midnitlove, Mar 19, 2001.
  1. midnitlove
    midnitlove Registered Member
    Mar 19, 2001
    53
    Orange County, California
    72\' K5 front axle replacement
    I just bought this K5 last month and I'm replacing the broken front axle shafts, plus everything else around it. I have it all apart and I have replaced all the parts and I'm ready to put everything back together. I cannot get the spindles/steering knuckle back onto the axle housing. what kind of magic do I have to pull off in order to get those things back on. For some reason the universal joint prevents me from getting any space to bolt the ball joints on. I know its a snug fit but i could not get them on. I took the joints apart and even tried taking the ball joints off but no good there. I need about 1/8 of an inch more to get them on. I tried everything. I did not take off the brake shield. Those six bolts or so are still bolted on the spindle. My next step would be to take those off.
    Thanks,
    David
    AMIGOS SO. CAL
  2. extremeblazer
    extremeblazer 1/2 ton status
    Dec 5, 2000
    129
    Albany NY
    Re: 72\' K5 front axle replacement
    Remove the six bolts, this will allow you to remove the caliper mount/dust sheild and the spindle. With the spindle off install the steering knuckles with the axle shafts out of the axle. You will have lots of room to get to the ball joint nuts. Then just slide the axle in and put the spindle and every thing else on. I watched as someone spent hours trying to put every thing on with the axles in and final giving up removed the spindle.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yup, there you go
    Making the world better, one truck at a time.
    SW-ORD
