72 k5 tire rack
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by drchan, Mar 13, 2003.
  1. drchan
    drchan Registered Member
    Sep 4, 2002
    74
    edmond, oklahoma
    i'm trying to find out what tire rack my 72 would have probably had. When i got my blazer it didn't have a back seat so i don't know if it had one of those rear seat mounts. there is no indication of having a swing away rack. surely there was some kind of rack at one point. any info would be appreciated.
  2. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    If you check behind the rear seat on the driver's side you'll find 4 bolt holes in a square pattern. Those are the factory mount holes for a "standup" spare tire carrier... If you want "stock" that's what you'll need to find, but it won't hold a very big tire either....! /forums/images/graemlins/eek.gif
  3. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    If your truck didn't come with a rear seat (check the glove box sticker), then the rack was mounted as Greg72 mentioned. If it had a rear seat, it was the same thing, just behind the rear seat.
  4. drchan
    Sep 4, 2002
    74
    edmond, oklahoma
    i'll pull up the carpet and check. i don't have a sticker in the glove box i guess the previous owner removed it when it was painted. that rack would hold a 32'' tire wouldn't it? well i'd have to find a rack 1st assuming i have those 4 holes. thanks
  5. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    cleszkie has a 72 and his hole were on the pass side, we both looked and thats where the the nut were located.
  6. bouncytruck
    Oct 11, 2001
    858
    Bothell, WA
    I've seen several of the racks for sale on this board and 67-72chevytrucks.com board. Just keep yer eyes open. Maybe post on the wanted board. /forums/images/graemlins/cool.gif
  7. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    Here are some pics of the interior spare tire mount in my '72. I have an oversized tire (not huge,though) mounted. The bolt goes through a slot that is pretty long, so you should be able to adjust it accordingly. Good Luck!
    Interior spare tire mount
  8. drchan
    Sep 4, 2002
    74
    edmond, oklahoma
    making sure my orientation is correct, that tire is mounted directly behind the back seat, if you were to have a back seat?
  9. Ressurection
    May 9, 2000
    360
    Actually, that is right behind the drivers seat, the tire staring the rear seat passenger in the knees. Hope that clarifies it!
