72 Scout dana 44 3.73 R&P fit in 73 k5 front end?
Discussion in 'The Garage' started by Joe Kitzmiller, Sep 13, 2005.
  1. Joe Kitzmiller
    Joe Kitzmiller Registered Member
    Dec 20, 2004
    25
    West Virginia
    Will 72 Scout dana 44 3.73 ring and pinion fit in 73 k5 front end? Is the dana 44 for both the 72 Scout and front end of 73 blazer the same? What is the difference between standard and reverse rotation? What is needed for the front end of the k5? Is the ring, pinion, and carrier the same for a dana 44 rear and front? Or is there such a thing as a dana 44 rear end? Basically, is the ring and pinion for any dana 44 universal, it will fit in any front or rear end regardless of make of vehicle? Appreciate some help with my education on dana 44's. Thanks
  2. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    The gears will work.
  3. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    A dana 44 is a dana 44.
    Just not 100% sure as to hp vs lp :confused:
  4. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    If the gears are not the proper rotation they will not get adiquit oil.
  5. Joe Kitzmiller
    Dec 20, 2004
    25
    West Virginia
    Thanks guys for the replies.
    Jhellwig.
    The chemical plant I work (Pt. Pleasant, WV) at is looking for an IT supervisor and DCS supervisor. Just to let you know, its good pay.
  6. Joe Kitzmiller
    Dec 20, 2004
    25
    West Virginia
    Steve,
    what is hp vs lp?
  7. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    hp- high pinion lp- low pinion
  8. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    A D44 is a D44 as far as gears go (I'm pretty sure anyways) but a high pinion's reverse rotation gears are not the same as a standard pinion's normal rotation gears.
  9. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
    Thanks but I am no where near being a supervisor (I am only 3 years out of tech school) and need something that I don't have to move to.
