72 top on 71 blazer, Anyone?
Discussion in 'The Garage' started by chevy111, Nov 6, 2005.
  1. chevy111
    chevy111 1/2 ton status
    Oct 1, 2005
    348
    Sacramento, California
    I have a 71 blazer but would like to put a 72 one peace top on it. Is this possible? What needs to be done?
  2. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    I thought they were the same.
  3. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    should be the same...everything changed in 73
  4. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
    Well first you gotta disconnect everything going to the body, then unbolt all the bolts from the frame to body, then give a lot of people beer to come over and lift body. Reverse order for putting it on other thing.
  5. ecameron87
    ecameron87 1/2 ton status
    Nov 9, 2002
    115
    AZ, Tucson
    There are two tops out there for the 69-72 blazers. Single wall top, which is bolted from the top down, and a Double wall which is bolted from underneath the bed rail on up into the top. A blazer that came with a single wall top will have threaded pieces of steel lodged underneath the bed rail to bolt to.
    I think that you can interchange them without much problems. You just need to see what kind of tops they are. and what it would take to bolt them down.
  6. chevy111
    Oct 1, 2005
    348
    reply
    Yeah thats what I want to do is change to the single wall top. I haven't had problems with my top but would like to have the convenience of taking the top off without removing the panels. Also I like the fact they have lights in them. And I have heard that the double walls can seperate and leak. I suppose you could weld threaded nuts at the bottom.
  7. ecameron87
    Nov 9, 2002
    115
    AZ, Tucson
    You could weld threaded nuts to the bottom, but you might have a hard time alligning the top to the bolt holes. Mine came with a single wall top and it has threaded plates that sit in a channel so that the plates can slide forward and backwards. This way, it has a little bit of adjustability when putting the top on. Remember that when the top is off, the body changes shape slightly unless you have a roll cage in there holding it all together.
