73 12bolt same as 79 12 bolt? fair trade?
Discussion in 'The Garage' started by moturbopar, Feb 27, 2005.
  1. moturbopar
    moturbopar 1/2 ton status
    Feb 9, 2005
    387
    mesa az
    Hi all, I have a 79 blazer with the 3.07 gears, I bought a set of axles that were supposed to have 3.73 gears, the 12 bolt is 3.73s but the 10 bolt has richmond 3.90 gears! Anyways I found a front with 3.73 gears and purchased my lockrite for the 12 bolt, unfortunatly I found that the 12 bolt has a gov-lok! So on went me search for an open 373 geared 12 bolt. After looking at 8 different ones and finding ALL of them being gov-loks I just gave up and and deciding to just use the gov-lok I started grinding off the shock mounts on my 3.73 gov-lok. Well today my uncle comes ofer with his truck complaining about fuel economy and asked if I wanted to trade my 3.07 gov-lok rear for his, After checking it, it is a 3.73 open! (cant beleive im excited about an open diff:o )
    So here is my question, the rear axle I have is the 79 3.07 6bolt and his is a 73 3.73 5bolt, is there any problems with me just switching axles from one housing to the other? truck 12 bolt axles are truck 12 bolt axles, right?
    Shawn
  2. diesel4me
    Jul 24, 2003
    17,552
    939
    Massachussetts
    I've swapped em
    I put my 6 lug rear axle shafts in a 5 lug 2wd truck axle before--I'm not sure if all years are the same spline,dimensions,etc-(probably,but again,I'm uncertain)--but it worked for me--a hollander interchange book at a junkyard will have the info you need, or maybe someone here can tell you more..:crazy:
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Experienced with this one , I have put 4wd axles in the 2wd housing and have had no problems . Just carry a spare anyway please .
    The only thing I encountered was the drivers side shock mount rotated too far away with my shackle flip and I run that shock upside down so it lines up with bolt holes , this is on a 73 longbed 1/2 ton 5 lug pickup housing .
    Be sure to use your later brakes , the earlier brakes are skinnier , and the backing plates are not as deep . You want the biggest shoes you can fit with these heavy trucks .
    So I say go for the open axle , use your shafts , put in the lockright , and wheel it , drive it , do what you want :D
  4. moturbopar
    Feb 9, 2005
    387
    mesa az
    Thanks! I was hoping for that answer.
    What part of Mesa are you in? I live by Power and Brown.
    later
    Shawn
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Broadway and Ellsworth . My Inlaws live near you though on Jensen north of Brown , east of Power . I am in the garage a lot lately , your welcome to stop by and have a beer :D
