73-75 winshield frame (how to cut off)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CK5, Oct 4, 2001.
  1. CK5
    May 19, 1999
    21,627
    704
    CO
    If I were to cut a 73-75 windshield frame off, should I just cut it as far down on the sides as I can? How do I pull the windshield? Do I need to bother with the rubber seal crap?
    Steve
    Bandwidth FREE ZONE
    Mall-Running poseur 4x4 with curb-feelers
  2. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Are you converting yours to a full convertable....... If so cut it down as low as possible to make sure you have area to trim it when your doing the swap..... To remove the glass I would cut the rubber to get the glass out.... It's probably hard and will brake the glass when you work at removing the rubber....Just buy new rubber when you finish
    C'moe
    Kill Roy was here!
  3. CK5
    May 19, 1999
    21,627
    704
    CO
    Still not sure yet... If I take the rubber off the front can I just kick the damn thing out from inside?
    Steve
    Bandwidth FREE ZONE
  4. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    74
    Humboldt/Pacifica, CA
    This is what I heard from a shop who has done several of these conversions. Cut the windshield posts at the middle, stick a piece of square stock inside the posts, weld the square stock to the posts and be done with it. The guy actually supported his weight from the top of the windshield frame after the mod so it is very sturdy.
    BTW: when you get the 73-75 frame get as much of it as possible.
    E PLURIBUS UNUM<P ID="edit"><FONT class="small">Edited by rampage on 10/04/01 01:36 PM.</FONT></P>
  5. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    After cut the rubber out and push ( with your feet for safety) the windsheild out from inside......
    C'moe
    Kill Roy was here!
  6. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You certainly should be able to - just use a sharp carpet knife and knock the whole front side of the seal off - it should basically fall out after that.
    Of the 5 toughest dogs in the neighborhood, my cat's ranked #3
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  7. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    it's about time you concider the full convertable "sheeeesh" you should also conscider new paint job something like mmmm..........i dont know orange and white [​IMG]
    <font color=purple>I put the Panic in Hispanic</font color=purple>[​IMG]
    <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
  8. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    There is a locking strip in the rubber gasket around the windshield. Take the strip out and carefully push the windshield out from the inside out, starting at one side and working your way over to the other. I just had my glass replaced and watched the whole thing. It came out easier than I thought it would.
    What, Me Worry?
    <a target="_blank" href=http://www.echobit.com:81/k5/> The 'BEFORE' pictures</a>
  9. CK5
    May 19, 1999
    21,627
    704
    CO
    Good idea, I wonder what size of stock? I guess I'll find out when I hack. :-)
    Steve
    Bandwidth FREE ZONE
  10. rampage
    Mar 20, 2001
    2,261
    74
    The biggest size that'll fit inside I would guess.
    E PLURIBUS UNUM
  11. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Steve,
    If I catch you in my garage with a sawzall you are going to have a lot of explaining to do
    I thought I was wrong once,
    but I was mistaken
  12. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Steve, do you plan to do this yourself or have it done?? I am a body man and I will help over the net the best I can.
    If ya can't stop.......Smile as you go under! [​IMG]
  13. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    Use a piece of piano wire with one person on the inside and one person on the outside and saw it around the window and, well, thats it, there you go, have a nice day.
    [​IMG] Sometimes you feel like a nut [​IMG]
  14. CK5
    May 19, 1999
    21,627
    704
    CO
    Yeah, tou can help me e-sand and e-paint. I will cut the top off myself prolly and maybe have Tim (although he doesn't know it yet) weld it on for me then have a body place finish the hole on the bed side, that's about it. I won't be able to do this until I get the rockers and cage done though so I can stiffen up the body.
    Steve
    Bandwidth FREE ZONE
  15. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    Steve what are you going to do about the Doors? I think that I am going to get another 73 but it needs doors and all I can find it 76 and up doors. Would you just cut the door and install the correct plates?
    Donovan
    <a target="_blank" href=http://www.rustbucket.rockcrawler.com>www.rustbucket.rockcrawler.com</a>
    Nitro Fumes makes me Horrrrny
  16. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Donovan, GM never made a "special" door for the '73 to '75 K5's. They just took a bandsaw to stock pickup doors to make 'em fit the K5's. [​IMG] You just have to move the blockoff plates and rubber end plugs from the old doors to the new ones. This makes it much easier to shop for new doors. You can even upgrade to later model doors with the nicer mirrors and interior trim. [​IMG]
  17. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    So you are gonna cut it off ? [​IMG]
    <font color=green>[​IMG]1977 K5 GETTIN IT AWN[​IMG]</font color=green>
    The flag still stands for freedom and they cant take that away !
  18. Donovan
    524
    Arvada, CO
    No welding required on the Doors? That is cool. That is one thing that I have never had apart. Thanks
    Donovan
  19. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    hey steve, Dave at KW ONE STOP did mine, he did a kick ass job, he cut it half way up and stubbed it, welded it and finished it. you cant even tell its not factory. you saw it, but dont do that part yourself, it has to be sized just perfect or the the windsheild wont pop in. i need to put on my hard top this week it getting a tad bit nipply at 4 in the morning on my wat to work!
  20. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    You can order the gasket with the trim or without it.........
    C'moe
    Kill Roy was here!
