73-80 front end on 84?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by one ton burb, Dec 21, 2005.
  1. one ton burb
    one ton burb 1/2 ton status
    Nov 15, 2003
    119
    Ontario, Canada
    Ok I know there has been a lot of post on putting a newer style (81 to 91) front end on older trucks but this is the other way around, what I want to know is if i could put the older style (73-80) style front end on my 1984 burb as far as i know just the wiper's are diffrent because the older front end dose not have a cowl cover and hte hood goses all the way to the window covering the wipers, so what mods if any would I have to do to make it work?:confused:
    thanks guy:bow:
    Tom
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    73-80 , the hood hinges and everything is mounted on the fender .
    81 up , hinges mount on cowl , springs between hood and fender .
  3. one ton burb
    Nov 15, 2003
    119
    Ontario, Canada
    So no mods to the wipers or cowl to fit the older front end? :confused:
  4. Desert Yeti
    Desert Yeti 1/2 ton status
    Mar 20, 2003
    320
    Tucson, AZ
    I've only ever had the older style, but based on what's said here, seems like if you swap hood and fenders from the donor truck it would work ok...but I don't know if the cowl is going to interfere with the old-style hood...
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The cowl cover comes off on the 80's models .
  6. one ton burb
    Nov 15, 2003
    119
    Ontario, Canada
    k thanks guys
  7. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    You will need the wiper transmission (linkage) and pivots from the donor '70s truck as the studs for the wiper arms are shorter. I've done this conversion, I put an '84 cab on my '79 K10.
  8. one ton burb
    Nov 15, 2003
    119
    Ontario, Canada
    thanks man thats the info I needed I knew there was something diffrent just was not sure what, so thanks again
