73 big burb so cal
Discussion in 'Complete Vehicles' started by basing110, Aug 22, 2006.
  1. basing110
    basing110 1/2 ton status
    Aug 4, 2005
    san diego
    my buddy has a 73 suburban for sale . has 454/465/205 /strong running 454 /has a d44 with a busted outer shaft/ 14 bolt rear with detroit /4.10 gears 12" superlift springs which have been modified and its now about 9-10" lift pulls some better flex /has 42" superswampers on standard 8 hole pro comp rims. has a drop pitman arm and raised steeing block but the axle is moving so it either needs a sway bar or x over steering to drive safely . it does not turn very well at this time .. needs front d shaft / have 429 heads that come with truck and also couple extra alternators subs and amp hes asking 2,500
