'73 Blazer Gear Ratio
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ChadH82, Jun 11, 2001.
  1. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    \'73 Blazer Gear Ratio
    I'm need to know what the gear ratios are in my Dana 44 and 12 bolt on my '73 Blazer. It has a 350/350/203 if that helps. Thanx.
    Chad
  2. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    Re: \'73 Blazer Gear Ratio
    Mine (same setup) has apprx 4.11's
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    mine is a 74 but they are 3.73....
    1974 Chevy Blazer Cheyanne. lots of plans for it....
    but it is on 33's now, with saggy old springs. i am in so cali if ya got any parts for me.
  4. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    the blazers came with a couple different options so the only way to know what you have is to either do the quick and semi accurate way or the right way. The first one is to jack up your rear end , make a mark on your tire on the driveshaft and spin the wheel forward for two rotations and count how many times the drive shaft turns. this should bive you an approxamate ration like three turns of the shaft=3.07 4 turns= 4.10. if you arent satisfied with this, pull your rean end cover off and rotate the ring gear untill you can see some numbers stamped on the end of it. Mine had 43:14. you take the larger number and divide it by the smaller number to get your ratio so mine was 43/14=3.07. its the proper way to do it if you really want to be accurate, but the drive shaft and tire method gave me an approx 3.07 so i igure its accurate.
    Check out my 73 K5 http://members.theglobe.com/xnoahx/73k5.htm
  5. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Most of them were unlucky enough to come with 3.07 gears, like mine used to have. Just pop the rearend cover off and count the teeth. The gearlube probably needs to be changed anyway.
    '73 K5
    Chevy good...Ford bad
  6. blazerbum
    blazerbum Registered Member
    May 14, 2001
    96
    lake stevens washington state
    im pretty sure your running 307's thats what my 73 came with but i put 373's in when i went to 33's DONT BUY your gears from 4x4 warrehouse unless you want alot of greif.
  7. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
