73 blazer vin's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by surpip, Sep 9, 2004.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    73 blazer vin\'s
    anybody have a 73 and know where the vin's are? i got the one on the door jam, there isent one on the dash, im looking for the one on the frame and any more there might be,
    thanks alot for your help,
    dale
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Re: 73 blazer vin\'s
    IIRC it is by the body mount by the front spring shackles on the drivers side..
    I will look brb
  3. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Ok it is about 1 ft foward of the rear front spring hanger on the outside of the frame.. /forums/images/graemlins/waytogo.gif
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i found that number, it also has the build date underneath it? but that number dosent match the one on the door jamb
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    oh drivers side, i found the one i was talkin about on the pass side, do you think i should swap that one too just to be on the safe side? any more? thanks alot man,
    dale
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    dale
    If you're in CA, all you need is one, either the body or the frame, and if you are swaping VIN's make sure you use the right rivets (rosette) or DMV will get you.
    /forums/images/graemlins/thumb.gif
  7. Jefferson-Mo
    Jefferson-Mo 1/2 ton status
    Jun 18, 2006
    141
    San Diego858, CA
    Or the CHP! :eek1:
  8. Jefferson-Mo
    Jun 18, 2006
    141
    San Diego858, CA
    Up from the dead........revive!
    HIJACK
    On my 80 there's a part number on the frame where the VIN should be?
    Replaced frame?
    Or should I look elsewhere
  9. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    The VIN will be on the TOP of the frame rail, that number on the side of the frame rail is a part number or plant number or something like that. But the VIN will be on the TOP of the frame rail.
  10. Jefferson-Mo
    Jun 18, 2006
    141
    San Diego858, CA
    Cool thanks
