73 Burb first tow
Discussion in 'Tow & Trailer' started by mudhound72, Jun 27, 2005.
  1. mudhound72
    mudhound72 1/2 ton status
    Feb 15, 2005
    474
    Oshkosh, WI
    This was just over a month ago but this is the first time I towed with it. For road manors it was sweet no bounce or sway for pulling 7,000+ lb on a 250 mi round trip. The one thing that I think is that the trany was not happy, the only way I could get it to shift rite was threw manual shifting, talked to a few guys and they fig the trans is still set up to be in a car, so this winter I will pull it out and have it set up. BTW if you don't know this has a 500 caddy with a caddy trans th400.
    The folowing weekend I pulled the Blazer on the same trip was a bit more happy but not much
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I have never heard of having a transmission set up differently between a car and truck only between gas and diesel. Does your kickdown switch work properly?
  3. mudhound72
    Feb 15, 2005
    474
    Oshkosh, WI
    From what I was told the converter has a different stall rate, and the shift points are a bit different, but we were also talking that a few of the clutches might have welded together. Just a few thought :)
  4. kennyw
    Jun 9, 2002
    13,224
    94
    Good thing those transmissions are cheap and easy to rebuild yourself anyway. But I know a lot of people used to use those Caddy's to tow with the car...
