'73 has rockers once again
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigjbear, Nov 24, 2001.
  1. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    \'73 has rockers once again
    I finished cutting out the old rockers. They were a combination of rusted steel, dirt, and roof flashing pop riveted in place. That left me with a 4" gap between the floor and the subfloor thing that the '73-'75s have. I cut some 4x4 square tube to fit. It was a little harder than it sounds because I wanted to keep the subfloor and there are a bunch of angles to deal with. I got the tube in, now I just need to tie it to the floor support and the frame. The outside edge is now 3" inboard of the stock location-about even with where the door seal would go. The hardest part was deciding what to cut out and what to leave. Once I put some doors on I am going to add some nerf bars as well. They will mount right to the 4x4 so I won't give up any clearance. Although I am still toying with leaving the doors off and making it a summer only truck and just using the '80 when I need things like a top or doors.
    Jim '80 GMC & '73 Blazer
    Body by Tellico
    <a target="_blank" href=http://www.tellicok5.rockcrawler.com>www.tellicok5.rockcrawler.com</a>
  2. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Re: \'73 has rockers once again
    sounds great!! i know what you mean about the angles. kind of a pain in the arse!!
    later rob
    350 TBI, 700R-4, NP241, D44-14FF, 4:10's, 38.5 TSL/SX's, full conv., full cage
    <a target="_blank" href=http://www.yeild2me.rockcrawler.com>www.yeild2me.rockcrawler.com</a>
  3. Grim-Reaper
    7,385
    Atlanta
    Big J. I'm not mounted to the frame at all and you have seen first hand how much abuse mine can take. What I do have is some bumpers on the end of some 2x2 so that if the nerfs get pushed from the side they push on the frame but it's not bolted to the frame
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  4. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Grim, It is just going to bolt to the frame at the end of the tube. It will bolt to the floor support for the front and middle mount. Depending on if I use 2x2 or 4x4 for the center support the center may or may not mount to anything. If I don't mount to something I will have to replace about 6" more of the floor sheetmetal. I did not want to tie to the frame but the floor support is not as solid near the back. My plan is do it like the picture I drew, it is just not as easy on the the truck as it was on paper. Any idea on what to use for a bushing at the frame tie point? Right now I am thinking of using a thick piece of rubber between the mount plate and the rail.
    Body by Tellico
  5. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    Hey Guy's,
    What's up. Sounds like I am missing some real fun back in GA. Well I thought that I would let you guy's know I now have the Blazer running. The TPI swap is complete and it runs great. The motor end of things is dialed in and working great. Now I have to swap the axles from the Robzilla to the Blazer. That for this weekend. Then some floor panel replacement and It should be trail ready. I got my new rear bumber from Kyle at KMA last week and will be putting on next weekend. Here are some pictures of the Robzilla II.
    See Ya.
    Rob Finelli
    AKA The Robzilla
    Here is the link to the pictures:
    http://photos.yahoo.com/bc/therobzi...onversion&amp;.src=ph&amp;.view=t&amp;.last=1
    <P ID="edit"><FONT class="small">Edited by therobzilla on 11/26/01 06:33 PM.</FONT></P>
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Rob, looks good. Is that the TPI from the 'Zilla, or did you get another one? Wish you could have been here for Dixie Run we had a great time ~ 6 full size Chevys on trail 9. You would have had a blast. The wife said "HI", too. Have fun on those AZ trails.
    Body by Tellico
  7. Grim-Reaper
    7,385
    Atlanta
    DUDE! man that looks awsome!
    Man I Agree with BigJ. Wishe you had been her for Dixie. Ken and I ran 11 (gardrail) On friday. We came down the back side of 11 instead of school bus. Both Ken and I shreaded the sides of our trucks LOL. took me half a day of pounding to get the fender out enough to get a tail light back in. I'm going to cut the fenders off the 74 Paul has and make them quick disconnect [​IMG] BigJ and I need to come out and wheel with you and AZ.
    TTYL
    75 Jimmy, Dollar
    Grim-Reaper
