73 K5 Blazer Upgrade
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rsb3, Jun 9, 2003.
  1. rsb3
    rsb3 Registered Member
    Aug 7, 2002
    5
    I have a 73 K5 Blazer 1/2ton 350 4 speed manual
    also have a K30 pickup, seriously thinking about using almost all parts from the 86 K30 pickup to upgrade my K5.
    The K30 has a 454, auto 400 turbo, 1 ton running gear (dana 60 and 14 corporate), doors with power windows, etc.
    Is it worth it for the conversion to upgrade the ol' K5?
  2. monte0172
    monte0172 1/2 ton status
    Sep 16, 2002
    182
    Memphis, TN
    Depends on if you mind sacrificing the k30 pickup. Personally I would!!!
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yes and do a search on this stuff. I not real sure but I can vaguely remember some crazy-talk about swapping in 1 ton axles... /forums/images/graemlins/thinking.gif /forums/images/graemlins/wink.gif
  4. rsb3
    Aug 7, 2002
    5
    what crazy talk about 1-ton axles?
  5. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    he's fawkin with you, it's only been covered about a million times thats all.... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  6. rsb3
    Aug 7, 2002
    5
    Well from what I have found out, the dana 60 will be a direct swap, the rear 14 bolt will need the perches relocated, the drivelines will most likely need to be shortened, at least in the rear, the doors will need to be shaved and capped, the 454 should swap right in, to replace the 350, the tranny still can go either way, manual or auto?
    any comments or suggestions are much appreciated! anything I am missing?
  7. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    If the k30 you have is a SWB I'd swap the blazer body onto the k30 frame and go through any additional trouble involved as the frame becomes the only week link when swappign all teh other heavy duty stuff over, but I'd do it!
  8. rsb3
    Aug 7, 2002
    5
    The K30 is a standard cab with a long bed.
    Are the frames different in steel gauge? not too familiar with the frames.
  9. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    All K30's are LWB and yes the 1 ton frames are thicker than the 3/4 and 1/2 ton frames, I do not know the exact numbers though. Other things to consider with the BBC swap: it requires different accesory brackets(ie alternator, PS pump, A/C etc), you most likely will have to upgrade to a 4 core rad, and I have heard of people having to make a small dimple in the firewall to clear the distributor...
  10. rsb3
    Aug 7, 2002
    5
    I was planning on using the whole engine setup (radiator, oil cooler, a/c, etc) If I swapped the Blazer body onto the K30 frame, Since the frame on the K30 is a little bit longer at the back, is it as easy as chopping some inches from the back? I would probably have to move the rear axle forward (relocate springs) and reduce the driveshaft length
