'73 K5 seat replacement suggestions sought
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by stu454, Sep 18, 2003.
  1. stu454
    stu454 1/2 ton status
    Sep 17, 2003
    129
    Corte Madera, CA
    \'73 K5 seat replacement suggestions sought
    Haven't picked up the '73 K5 yet, but I do know that the seats are shot. Suggestions for replacements? Buckets out of a Suburban or even a Tahoe are what I was thinking. Hopefully these can be had at a junkyard.
    What do you think? What have you done yourself?
    Thanks,
    Stu
  2. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    Re: \'73 K5 seat replacement suggestions sought
    I just replaced mine out of my 82 with some from an 87K5 worked good just drilled all new holes and put backing plates on them....I had some surburban seats in there they were different and had trouble fabbing up ....Jason
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah blazer seats would be the ultimate /forums/images/graemlins/laugh.gif
    too bad hard to find evne in bad condition /forums/images/graemlins/frown.gif
    dont ever try car bucket seats, they sit wayyyyyyyyyyy too low to the floor /forums/images/graemlins/frown.gif found this out the hard way in a 68 pickup. 88 cavalier high back buckets
  4. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Anything from an 88-up pickup or 92-up Yukon/Burb will work quite nicely. They have a flat cab floor just like the K5.
  6. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I have Geo Metro seats in mine...they're actually quite nice, except the driver's seat is starting to fall apart.
  7. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I kept the stock brackets and turned them into a 1 piece base using a 18"x18" sheet of 1/8" steel plate. Then I got some front seats from a '91 silverado. I had to drill 4 holes to mount the seats to the plates. I got the seats for $100 and the steel plates for $20. The best part is that everything bolted back into the stock location. So now I have nice comfortable high back buckets that recline and bolt up to the stock floor mounts in my '74. /forums/images/graemlins/thumb.gif They're nice and comfy!
  8. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    i have seen some of the bestop or steel horse seats for jeep put in a k5 and they looked real good and were real comfortable /forums/images/graemlins/thumb.gif
  9. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Bucket seats from the pop up headlight eclipse, laser, talon triplets work well both seats have a flat mounting surface I plan on doing this swap and they are very comfortable. Only problem is if you are lifted alot they are harder to get in and out of because they have pretty good side and thigh bolsters /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  10. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    I have seats from a 94? caravan, I got the front and rear seats for 35.00 at a yard on half off day, thay are perfect and recline I managed to use the blazer seat brackets too! /forums/images/graemlins/thumb.gif
  11. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
  12. stu454
    Sep 17, 2003
    129
    Corte Madera, CA
    Thanks for the help!
  13. atlantak-5er
    atlantak-5er 1/2 ton status
    Aug 20, 2003
    225
    Atlanta, GA
    I got some corbeau bajas for about $160 ea, went to the boneyard and got some brackets out of an 84 k5 for $25 total. They are comfy, have five point harness slots, and look cool.
