'73 K5 window regulator swaps?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mofugly13, Jan 5, 2004.
  1. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    \'73 K5 window regulator swaps?
    My drivers side regulator stripped the gear today. /forums/images/graemlins/mad.gif I knew it was on it's way out when I got the K5, so I've been loking around at yards for one in decent shape. In the LMC catalog, they list a part number for 1973, a different number for 74-76, and ANOTHER number for 77-91. When I've found a decent one at the junkyard(JY generally has '77-'85 or so Chevy trucks) it looks like the splined stud that the handle mounts on is longer than the one currently in my blazer. Does this mean I need to find a 73-specific regulator?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: \'73 K5 window regulator swaps?
    The splined stud is the only difference in the regulators due to the contour of the door panels are different, but any regulator from 73 - 91 will bolt it.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah its the length of the splined shaft that changed, 77-up are longer, thicker door panels so you are stuck with 73-76, i have one if you need ?
    good luck
