73 to 87 rear glass
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chaz316, Jul 25, 2001.
  1. Chaz316
    Chaz316 1/2 ton status
    Jul 25, 2001
    224
    Georgia
    I have a 73 K5 and I want to swap the tailgate to an electric 80s model. Is this a straight forward swap?
    73 K5, 350, auto w/factory air....How sweet it is.
  2. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    I'm not too sure about the geometry, but the fit shouldn't be a problem. I'm sure someone else on the board can answer that question. So that leaves the wiring which really shouldn't be that hard. Email me privately when you start the work and I'll copy the wiring diagrams if you don't have them.
    John
    John
    <P ID="edit"><FONT class="small">Edited by TwoCrows on 07/25/01 08:30 AM.</FONT></P>
  3. Chaz316
    Jul 25, 2001
    224
    Georgia
    Ive found a couple of late 80's K5s here in Augusta. Im trying to snag the interior also but most of them have been gutted. The back glass on my original tailgate doesnt function like its supposed to. Plus its kinda rusty too boot. I had an 87 and I liked the convenience of the power back glass.
  4. TwoCrowsDesign
    Jul 13, 2001
    387
    Yeah, the window channel on my 89 rotted away and the window was running up and down on those two little posts that hold the channel too the lift mechanism. Well I always had to help the window down because it wasn't attached any longer, one day I was helping it down and it just shattered into a million pieces. It was kind of funny as my wife and I just stood there looking at each other with a look on our faces that clearly said "well, that was gonna happen".
    So I cannabalized the 88 to get a window back in the thing, but I think I found a guy with the parts, fingers crossed...
    <P ID="edit"><FONT class="small">Edited by TwoCrows on 07/25/01 08:40 AM.</FONT></P>
  5. Chaz316
    Jul 25, 2001
    224
    Georgia
    Yea Im trying to avoid that situation. I have not let the rear window down since I have got the truck. Hopefully if the glass in the newer tailgate is different maybe the old glass will work on the new gate.
  6. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Fyi, the glass is the same 73-91
    the rail that the glass attaches to maybe different !
  7. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    the channel at the bottom of the glass, the rollors and the rollor channels are all available from gm still. for under 100.00. don't tell them it's for an older truck. Tell them it's for a 91 blazer.. There all the same. I have found that if it's an older truck, they don't want to look parts up.
    your right. I don't understand the jeep thing!
  8. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    Actually, as slow as my 87 power window is, I'm considering switching to an old style crank.
    Karl
    Temporarily Unemployed Underwear Model
    87 3/4 ton
  9. Chaz316
    Jul 25, 2001
    224
    Georgia
    If the window is slow in your 87 I have found that a little wd-40 sould help things speed up a bit. It works on the power window motors in the doors.
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The slow window is easy to fix. Open the tailgate and remove the cable that transfers power from the motor to the crank mechanism. I'll bet that the cable will barely spin. It should spin freely. Lube or replace the cable and your window will go up and down quite nicely! [​IMG]
  11. Chaz316
    Jul 25, 2001
    224
    Georgia
    Yes but will a new power back window work on an older manual back windowed k5?
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Sure will, you just have to run all the wires and stuff to it. I've got an '88 power tailgate sitting in the garage just waiting to be swapped into my '75.
