73C5blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 73C5blazer, Apr 14, 2000.
  1. 73C5blazer
    73C5blazer Registered Member
    Apr 14, 2000
    6
    I have a 73Cheyenne equipped 2wd blazer with a 12 bolt rear end.
    option no.
    1ZN8
    description
    optional axle ratio
    What is my rear end gear ratio? If you answer this question, what book did you get it out of and where can I find a blazer option and code book? J541R@aol.com
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    You might try this question on the main 4WD page, lots more people look at it. I would count the number of tire rotations to driveshaft rotations if all else fails.
    Michael [​IMG] http://jmartin.net/parker/goose.htm
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The best way to do it would be to take the cover off and count the number of teeth on the ring gear and divide it by the number of teeth on the pinion. This is the most acurate way to do it, and most people neglect to change the oil in the rear so you should do that anyway if you just got it. Good luck!</font color=blue>
