74 body on a 77 frame
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mud390, Oct 31, 2002.
  1. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    I have a few questions... Will a 74 blazer body bolt directly to a 77 chassis? I have heard of problems with the rise in the rear frame rails. It that going to be an issue? Also, the blazer body comes with an 87 front clip. What issues will I run into there, or will it be a straight bolt up? My 77 currently has a 3" body lift on it. Will this cause any snags in the body swap or will it be indifferent? Thanks for any help!
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I don't see why it wouldn't, I believe 73-77 has the same chassis.
    78 was the 1st year of the raised floor.
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Yep, what Ron said. It should be a direct swap.
  4. tRustyK5
    Jul 23, 2000
    36,169
    1,370
    E-town baby!
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    73-77 had the same fronts, only the grill was different.
    78 had the change in headlights and front end.
  6. mud390
    Oct 31, 2002
    1,210
    thanks for the information! I am now considering this more seriously. Hope it works out....I'll let y'all know. Thanks again.
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    1) Fill out your profile. Because if you are in California, you do not want the 74. Because 1973 is the cut off for the smog requirements
    2) i have a '77 and have a "raised floor board" in the rear. The driver seats are below the bed. not flat all the way through as the 1st gens are.
    3) Fill out your profile
