74 Cab/80 Frame Swap
Discussion in 'The Garage' started by drofdar, Aug 17, 2004.
  1. drofdar
    drofdar 1/2 ton status
    Dec 7, 2003
    113
    Fresno, CA
    I want to go smog (CA) exempt by swapping a Chevy 74 1/2 ton cab w/title to my 80 3/4 ton frame. Both are 4W/DR. Will this cab fit on my 80 truck?
  2. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    If you put your ’74 body on your ’80 frame you will still have a ’80 truck and not escape bi-annual smog inspections. The registration and smog inspections are based on the frame year and VIN, not the cab.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    not sure on all the smog stuff, but the cab will fit, shouldn't be any problems either.
  4. dremu
    Feb 27, 2000
    15,965
    456
    East of San Francisco
    Actually, '74 trucks did NOT have the VIN on the frame, so the DMV goes by the cab VIN. You will need it in TWO places, however, for the inspection, so the doorjamb and glove box or the like should match.
    -- A
  5. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    The '74 cab and '80 chassis will bolt right up with no problem, I did that swap several years ago when my '80 cab rotted away. Good luck!
  6. BAJA_BLAZER
    May 17, 2001
    517
    San Diego, CA
    -- A
    ...but the '80 frame will still have the VIN on it. Also, more than just a VIN on the frame is used to determine what year it is. What he is doing is called a "Cab Change" and there are specific procedures to follow. Call you local CHP VIN Officer and find out how he wants you to do it, if you want to keep it legal!
  7. dremu
    Feb 27, 2000
    15,965
    456
    Missed that part /forums/images/graemlins/doah.gif I stand corrected.
    -- A
