75 k5 rear tires track inside of front tires
Discussion in 'The Garage' started by k5zx, Oct 23, 2006.
  1. k5zx
    k5zx Registered Member
    Mar 11, 2003
    29
    I am almost sure this is what I need, but would appreciate havind it confirmed before I spend over a hundred dollars to get them.
    http://coloradok5.com/wheelspacers.shtml
    From behind my truck you can see the rear tires are inside of the front ones.
    thanks for any help
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yep those be it
  3. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Stock track width for a 1/2 ton K5 is 65" rear (WMS to WMS) and 67.5" front (WMS to WMS)
    1.5" spacers will do if it bothers you that much. You could also run less backspace on the rear rims...but this makes tire rotation a bit difficult. Personally the difference in width doesn't bother me any.
    rene
  4. k5zx
    Mar 11, 2003
    29
    thanks you two. are all of our K5s six bolt wheels? Mkine are stock I just want to make sure. and don't have my chiltons and can't go outside and lok because the truck is several hours away at my fathers house
  5. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Yup, stock K5's were all 6 lug.
    Rene
  6. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    Isn't the purpose of the smaller track width to help with turning radius?
  7. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    fixed it for you you can't forget about the few 5 lug 2 wheel drive k-5's
  8. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    This is an ongoing debate. Most subscribe to the turning radius theory, some to the stability theory (think defensive driving not off camber), and there were some others that are escaping me...
  9. badmix
    badmix 1/2 ton status
    Nov 7, 2004
    4,205
    60
    West Virginia
    Dont wheel spacers put undo stress on the axles and bearings? Ive thought about them, and yes , the rear does bug me. lol. But id like to know im not goin more damage than good by goin to wheel spacers. I want longetivity and durability outa my rig.
  10. dyeager535
    26,980
    Dunno about the bearings, but rarely are the axles the culprit in rear 10 bolts when they fail. I wouldn't be worried about it.
    If you were still worried, you COULD run repair bearings that move the bearing closer to the wheel, but again, IMO, not that significant a concern to worry about.
    Either that, or just keep your eyes open for a cheap, wider 6 lug 14SF in your gear ratio, and not worry about ANY of it. :)
  11. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I don't like the way it looks that the back sits in. Once I started denting the body up, the way it looked went out the window. Some of the guys I wheel with think that in the mud it makes a difference. two different ruts you were digging. It does help with turning radius though. we probably don't notice, but if you got scientific about it there would be a difference.
  12. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    if you swap in a 14ff would that widen the back out or is it the same as the 10 and 12?
    Shawn
  13. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    I don't know if the measurements are the same but the width is still narrower. I know the van 14b is the widest.
  14. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    I have a 14 bolt FF out of a 75 3/4 ton. it is narrower then the dana 44 I had and the dana 60 I have now. never measured but would venture a geuss it is the same width as the old 10 bolt that was under there.
  15. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    the 14bff's out of a van (maybe 1 ton only?) are wider to even up the track. but then you have to move the spring perches for a 1/2 or 3/4 ton rig (assuming it's out of a one ton)
