75 smog laws
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 98sub454, Jan 26, 2003.
  1. 98sub454
    98sub454 Registered Member
    Jul 18, 2002
    74
    La Habra, CA
    Im about to buy a 75 K5 and i read that only the early models did not come with cats. the current owner said that it doesnt have cats and never did. Right now the registration on the truck has currently expired and i am afraid that if i buy it i will have to put cats on it. Is there a way to tell if the truck originally had cats? also do i need them for smog? he is telling me that i dont and i am not sure about this model year so i figured id try and ask it here.
    thanks in advance
    /forums/images/graemlins/k5.gif /forums/images/graemlins/burb.gif
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Fill in your profile so we know where you are as to smog relates! And My 76 was not equipped with cats or air pump!
    Bill
  3. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    My '76 also had no cats or pump /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. 98sub454
    Jul 18, 2002
    74
    La Habra, CA
    sorry, im in socal. i figured you guys would assume ca since i am talking about smog laws. since we have smog laws up the ass
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> If it was built for the CA market than it probably had cats, but if it was built for any of the other 49 states (called "federal" smog) than it didn't have them. There is a way to tell from the engine code in the VIN IIRC. I know this because I have a 78 that was built for the Washington market. No cats and it smogs fine since it is a federal vehicle. </font color>
  6. Mike87
    Mike87 Registered Member
    Feb 18, 2000
    20
    San Jose, CA, USA
    My '75 never had cats or a pump. I checked the laws here in CA and found that if the GVWR was over 6000 lbs. you do not need cats or a pump, just a PCV valve and the thermostatic air cleaner. I had my truck smogged in December and it passed, no problem. Hopefully that was my last smogging!! By the time two years rolls around again, it should be exempt.
    Good Luck,
    Mike (#87)
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    6,001lbs and more was cat equipped, until 79 whne that changed to lower than 6,001lbs, look on your door sticker, and see what the gvw is of the truck, the Gov'y caught up to what GM was doing with increasing GVw of the 1/2 tons and rules changed in 79 so that 1/2 tons were cat'd from then on
  8. 98sub454
    Jul 18, 2002
    74
    La Habra, CA
    ok thanks. im not too worried about it because next year it will be exempt, but i just wanted to learn more about what i was gettin into for this year.
  9. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    75 didn't have cats, but some had the air pump which was stupid since the AIR pump doesn't do anything without a CAT. /forums/images/graemlins/thumb.gif
  10. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Ahhh, the heavy half. /forums/images/graemlins/rolleyes.gif
  11. dyeager535
    26,980
    Don't think that's entirely true.
    The GM car AIR applications (at least 81-87 in mid size RWD apps) divert AIR to the cat under driving conditions, but under cold engine conditions pump AIR into the exhaust manifolds, so it can further combust right there. (which is one of the reasons AIR is injected right at the exhaust port. Actually into the exhaust port, in some other GM engines)
    Most of the early (prior to '84 at least) trucks equipped with AIR and cat's didn't divert AIR to the cat at all.
    I don't doubt that AIR injection helps the converter do its job, but the cat isn't the sole reason AIR is there. (AIR has been around since the 60's)
  12. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well I see what you are saying, but I talked to a lot of smog guys, and what their experience says is that injecting air in the exhaust isn't doing any difference except when there is a CAT that is hot enoguh to ignite the residue with the air added.
    I am in no way an expert but I know my Physics and I talk to a lot of people, and so far that is what I learned.
    I didn't know that AIR started in the 60's though, do you know in what applications?
  13. dyeager535
    26,980
