'76 4x4 Pickup - SOLD
Discussion in 'Complete Vehicles' started by longbedder, Oct 19, 2006.
  1. longbedder
    longbedder 1/2 ton status Premium Member
    Oct 26, 2005
    4,202
    364
    Ridgecrest, CA
    Solid truck, clean title, passes smog, registration is paid through Oct '07.
    350 engine, runs strong/smooth, good oil pressure, temp stays right at 180.
    TH350 tranny, no burnt fluid, no slipping, shifts firm.
    NP205 t-case, fixed-yoke rear - 'nuff said.
    D44 front - wheel bearings, seals, brake rotors, and pads new last year
    12-bolt rear - axles are 3.73 gear ratio
    33x12.50-R15 A/T tires on aluminum 6-lug wheels - tread is about 60%
    4" Tuff Country front springs, ORD shackle flip rear
    Bucket seats - not sure what they're out of, but I made a custom frame for 'em.
    Custom tube bumpers front and rear, both with 2" receivers in the center. Tubing is 1.75" O.D. x 0.120" wall. ProComp floodlights on front bumper.
    Fenders are trimmed for clearance front and rear.
    The coating is primer, and has been since I got the truck 3 years ago. I live in the desert, and haven't gotten around to painting it. The pink stuff you see in the pics on the hood/front fenders is old (original?) primer where the gray stuff wore off. No bondo anywhere.
    This truck is pretty capable off road. I've done highways, trails, rocks, snow, mud, Mexico, Death Valley, LA with no problems.
    SOLD. I live in zip code 93555, and may deliver within a couple hundred miles.
  2. longbedder
    Oct 26, 2005
    4,202
    364
    Ridgecrest, CA
  3. longbedder
    Oct 26, 2005
    4,202
    364
    Ridgecrest, CA
    Good truck, still got it. Bumpity-bump.
  4. longbedder
    Oct 26, 2005
    4,202
    364
    Ridgecrest, CA
    Alright, seeing as truck prices seem to be in the crapper this year, $1000 takes it.
  5. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    how many miles are on it?
    Shawn
  6. longbedder
    Oct 26, 2005
    4,202
    364
    Ridgecrest, CA
    Unknown actual mileage - odo is "beyond mechanical limits" on my title (it's rolled over).
    Engine/tranny have approximately 15k on them. Ujoints, wheel bearings/seals, brakes (exc. master cyl) have approximately 3k on them.
    I've had the truck for 4 years, and used/maintained it regularly with no real problems. It doesn't leak or burn fluids. Tire tread is good.
  7. patt107
    patt107 1/2 ton status
    May 15, 2005
    276
    north carolina/new york
    I wish you were closer to North Carolina, ide take this thing off your hands.
    pat
  8. poolcues
    poolcues 1/2 ton status
    Dec 13, 2004
    232
    Charlotte,NC
    x 2
  9. longbedder
    Oct 26, 2005
    4,202
    364
    Ridgecrest, CA
