76-78 Caddy Calipers
Discussion in 'Parts & Trucks Wanted' started by cbbr, Jun 23, 2006.
  1. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    For a disc swap. Anyone got a set?
  2. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,235
    284
    San Jose, California
    I just had some I pulled from a wrecking yard. It might be worth looking for a caddy eldorado somewhere nearby since shipping might be expensive. They cost me ~$20 each but I was using them as a core exchange since I bought new ones. The core refund was $45 each.
  3. cbbr
    Jul 17, 2004
    14,681
    Where did you gt the new ones? Were they loaded?
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Might be better, cause new ones do not come with the spring or lever.
  5. bp71k5
    Mar 31, 2006
    6,235
    284
    Seems most any autoparts store has them. Napa didn't have the lever or spring for the ebrake, and it seems none of them come with those anymore. I was lucky to find one caliper with a new lever, but that was all they had. You might have some luck in another part of the country if someone still had them in stock. GM discontinued the part so the dealers can't even get it. I was lucky to find some in the wrecking yard so I can use the levers from them. They are ~$100 each for a loaded caliper. You can also buy some from BlackWidow performance brand new for $300/set.
    The wrecking yard is your best bet for the levers.
  6. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    the chevy stealership has the arms
  7. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i've had a core set for a while i've been wanting to give away just pay for shipping. I swapped out the piston so it wont work if rebuilt. comes with spings and levers. one spring broken but modifed to work. send me an email or PM.
    ARQ.
    arqdennis@sbcglobal.net
  8. cbbr
    Jul 17, 2004
    14,681
    PM Sent. Thanks.
