76-91 full convertible conversion
Discussion in 'The Garage' started by hatchetharry, Jan 13, 2004.
  1. hatchetharry
    hatchetharry Newbie
    Jan 12, 2004
    3
    first let me say as a "newbie", amazing site. now to the ?
    im planning on cutting off my half cab to make a full convertible and I could use any tips you might have. do i need to reinforce anything (windshield frame maybe)? i also want to scrap my stock doors for some steel tube doors. anyone see any future problems?
  2. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    I changed my '90 to a Full Hardtop Convertible ('73 to '75) by cutting off the steel half cab in the middle of the A-pillar/windshield frame and at the bed rails just behind the doors. I used the "eyebrow" (top of the windshield frame) off of a donor '73 and welded it on at the A-pillar cut. I used a section of bed rail from the donor '73 to fill the hole in the bed rail where the top was cut off. I also had to modify the doors (cut off the upper window frames) using the rusted out '73 doors as a template and to scavenge some brackets that were needed to welded into the '90 doors to make them match. I now have a '90 Removable Full Hardtop Convertible with full power doors and tailgate. The top fits perfectly (as good as it did on the '73) and spends most of the summer in storage.
    The real problem you will have in doing this is that without the Rocker Boxes under the doors of the '73 to '75's that was there to strengthen the body in the doorframe area, you will get too much body flex. The best solution is a full cage that ties in the A and B-Pillars at the top and bottom. But without a steel cab you should have a cage for safety anyway. It only took a friend and me 5 hours to complete the project. The cage is another story. I took full digital pictures of the project and one day will write a how to article. Good luck! You will love it when it's done. I get more looks and "thumbs up" when the top is down, than you could ever imagine.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Like this? /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif Click here
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Here is my 87, converted.
  5. one ton burb
    one ton burb 1/2 ton status
    Nov 15, 2003
    119
    Ontario, Canada
    [/ QUOTE ] I love the the full convertible look I should do it to my burb/forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  6. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Ive though about doing it to a burb many times I think it would be COOL /forums/images/graemlins/thumb.gif
  7. chubbybob
    chubbybob 1/2 ton status
    Oct 18, 2002
    730
    I am doing the same thing to a crew cab. I thought about putting a blazer body on my frame but I want 4 doors on a shortened chassy.
  8. hatchetharry
    hatchetharry Newbie
    Jan 12, 2004
    3
    thanks for the help, guys. a full cage will definitely be in the works, along with rocker guards. i don't have a donor 73 (if i did i'd probably restore it), so i'll have to fab up the pieces for the bedrail and windshield frame. shouldn't be too hard. i look forward to reading a how to article and any other tips in the future. when it's done i'll post pics (if i can figure out how to post pics!) thanks again,
    micah
