76 blazer with 33's on a 4' lift Im 42' high
Discussion in 'The Garage' started by ike, Feb 2, 2006.
  1. ike
    ike Registered Member
    Jul 5, 2005
    96
    orange ca
    What size lift did this guy sell me ?? I asked for a 4' BDS spring kit ... Im 42' high at the tip of my front wheel well. With 33's Is this right ?
  2. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    4 foot lift huh? thats huge. ' = foot, " = inch. sorry just had to let ya know. id measure mine but i dont know what size lift i have.
  3. JohnDeere
    JohnDeere 1/2 ton status
    Jan 17, 2006
    342
    Houston, Texas
    yeah its right cause i have a 3 inch lift with 33s and it sits like 40 and half inchs high at the wheel well
  4. ike
    Jul 5, 2005
    96
    orange ca
    More fun then I deserve....
    OK Great .That makes me feel better. I thought I was running into added work due to the wrong size lift. It sure looks high. I had to have extended brake lines for the front made.. Im sure Ill have to do the same for the rear... Now that Im putting the rear springs on Im finding the parking brake cabeles are in the way... Im not sure if they go over or under the springs...I looked up past post and It seems others that ran into this problem added a new bracket and rerouted the cables..or just removed it... The exhaust hits the rear hanger...its a crappy system anyway.....The best part of all it looks like by the angle of the drive lines Im going to need to made or buy a transfer case drop and extend the drive lines ....I have had several classic and custom hotrods but this is my first FWD and boy what fun Ive been missing.. this is turning into more fun then anyone ,, let alone I deserve...
  5. ike
    Jul 5, 2005
    96
    orange ca
    It gets better
    If you like that you should look up all my post ... and keep track of future ones.. Im a very poor writer and speller and thats trying to keep away from the big words like ... huh ....Thanks LOL
  6. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    i say drop the case and than see where your gunna be
    if the angles still bad than get some axle shims...
    LUKE
  7. ike
    Jul 5, 2005
    96
    orange ca
    Drop the case
    To drop the case should I make a braket or buy a kit? What happens to the engine mounts when you do this ? just let them twist?? Is it a bad thing to shim the rear diff.? Thanks
  8. JohnDeere
    Jan 17, 2006
    342
    Houston, Texas
    if u drop the case ur going to make ur front driveshaft angle worse
  9. ike
    Jul 5, 2005
    96
    orange ca
    Transfer Case Drop
    I think your right... What did you do??
    what are my options
