76 Caddy Calipers Interesting Info...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AZ_Overdrive, Mar 5, 2004.
  1. AZ_Overdrive
    AZ_Overdrive 1/2 ton status
    Dec 18, 2002
    117
    Arizona
    I picked up a pair of 76 Caddy calipers a couple of weeks ago and I noticed something rather interesting when we removed them from the doner vehicle. The brake lines were SOLID all the way to the caliper. I helped the salvage yard guy take them off and I was quite surprised to see that there were no rubber hoses between the axle hard line and the caliper. The line did have a "U" bend in it just before the caliper.
    So, these things came factory with hard lines and the 76 Caddy didn't look like there was any problems with metal fatigue or chaffing.
    Just wanted to mention it...
    /forums/images/graemlins/thinking.gif
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I remeber my buddy mentioning that , and we argued for an hour. I say go rubber/stainless in case , better safe than sorry /forums/images/graemlins/waytogo.gif
  3. frankin5
    frankin5 Super Mall Crawler Premium Member
    Oct 15, 2002
    882
    114
    chico,calif
    they have a rubber hose at the front of the trailing arm. since the the trailing arm and the caliper are moving at the same potental there is no need for flex at that point. /forums/images/graemlins/k5.gif
  4. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    Wouldn't it be a little easier to service the brakes with a rubber line at the caliper so you could swing the caliper out of the way without disconnecting any lines? /forums/images/graemlins/thinking.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That is not true. The caliper is constantly moving as pads wear and as the brakes apply and release. Any time you have a disc brake caliper, it must be fed by a hose, PERIOD.
    If indeed the factory screwed up that bad, I suggest you take over where their engineers left off.
  6. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    The "U" bend is what allows the caliper to move. If metal fatigue was breaking the line before rust-out in the 70's that might have been an issue. Don't forget the rears provide less of the braking capicity so they will not wear as fast or move as much. Where did you get your enginering degree?
