76 d44 question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazing86, Apr 11, 2002.
  1. blazing86
    blazing86 1/2 ton status
    Dec 24, 2000
    290
    Im using the flat top knuckles off a 76 flat top knuckle 3/4 truck Im using the outers from this axle on my 86 10 bolt. Will the axle shafts from my 10 bolt fit with these outers? Or will i have to get diff bearings or what?
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Knuckles out will interchange between D44 and 10 bolt. Your 10 bolt axles will fit the spindle bearings on the D44 spindles if thats what you mean. Outer axles are the same for D44 and 10 bolt ALL years.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have heard that some stubs from some 10 bolts have an extra snapring provision for automatic hubs, but that stubs from D44 and 10 bolt interchange if you don't have auto hubs. Inner axleshafts do NOT interchage.
