76cc to 64cc compression ratio
Discussion in 'The Garage' started by b454rat, Mar 22, 2006.
  1. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I used to know how to figure it out, but it's been a long time since I've messed with engines. I have a stock 400 with the awesome 76cc heads, guessing comp ratio is around 8:1. If I put the Vortecs with 64cc's on it, what would the compression be on it?? Piston kits used to tell you what it would be with different CC heads, but can't find that info anymore.....
  2. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    The SB400 that I had was about 10.5:1 with flattop pistons and 041 casting 64cc chamber heads. If you still have the factory style dished pistons my guess may be like 9.5:1. But I'm no expert at calculations.
  3. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    You are pretty much dead on with that assumption. The piston will dictate what your true compression will be.
  4. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    The motor is 100% stock. CR is around 8:1 on these, looked at a couple pistons and listed the ratios above. Now I need an intake. Anybody have one?? (cheap)
  5. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,029
    1,347
    Kzoo, Mi
    8:1 seems low for stock should be 8.5 at least.........I would believe it would raise about .8:1 for the 12cc in combustion chamber difference. Should give about 9.3 for the 4 valve relief style flattops
  6. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Not sure on the ratio, but I know in the 70s pretty much everything got low compression for emissions and crap. As long as it's under 10:1 so I can run pump gas with it.
  7. 76zimmer
    Nov 14, 2005
    23,029
    1,347
    Kzoo, Mi
    should be good to go. I run 9.5cr with my Vortecs, and run unleaded 89 w/ 8 degrees initial and 34 total in by 2500rpm; no knock even while pulling a trailer.
  8. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Just to give you an idea, if you have 9:1 comp. with 76cc heads, then you will have 10.25:1 with 64cc heads....all other variables remaining the same.
    With 8.5:1 it would jump to 9.4:1 with 64cc heads.:D
    There are quite a few more determining factors than piston shape when figuring compression ratio.:deal: :D
  9. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    as low as 8.0 Cr was very common, just look at the pontiac v-8s in the 70s alot of them were 8.0CR stock
    im not sure on the 400 chevy engines, but they were probably not much more, if at all
    make sure you srill the steam holes in the vortechs or whatever heads you use
    good luck
