'77 1 ton dually
Discussion in 'The Garage' started by 84gmcjimmy, Aug 20, 2005.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    chev 1 ton dually, 12' flatbed, 6k lifting arm...
    what axles would this truck have if it is 4x4? engine?
    what is a lifting arm?
    in the newspaper for 750 :eek1:
  2. 90BCk5
    90BCk5 1/2 ton status
    Apr 8, 2005
    278
    British Columbia
    doooooo eeeeetttt!!! :eek1:
    the lifting arm is probably one of those hand crank, flat deck mounted mini hiab lift things....
    i would say a d60 and dually 14 bolt....
  3. dremu
    Feb 27, 2000
    15,952
    443
    East of San Francisco
    Well, the rear will be some kind of dually 14BFF ... could be narrow so-called cab-and-chassis one, if the truck didn't come with a bed, could be the wider dually bed style. Neither will drop into a K5, even if you change the spring perches and/or shock mounts. (The C&C is crazy narrow, the regular dually a bit wide.)
    if it's 4x4 -- not likely -- it'll have a dually (DRW) D60. You'd need to swap hubs or use H1 wheels (crazy backspacing) to get it to fit under a Blazer easily.
    In short, sorry Stave, but don't get your hopes up :(
    -- A
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    60's didnt come out till 78 though right? that would mean thats 44 under it.
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    So the rear axle is a no go?
    If it doesn't have a d60 I will forget it...I hope they came out in '77 and not '78
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    '77 was first year of the 60's and K30's.
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    If it is a 4x4 and not a C&C then both axles are good. If it is a wide 14FF you can put the SRW hubs on the axle and it will widen it another 3-4 inches and will be almost the exact same width as a DRW dana 60. Then all you have to do is run stock H1 rims with the stock backspacing. Several guys have done that on here. I think Poohbear is one of them but I think his is a dana 70 same principle though.
    Ira
  8. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    if it is a 4x4, you can use the axles as they are like said before with H1 wheels and it will be fine. one thing is 77 is the first year of the D60.... SOO if its an early build truck then it may havea D44....
    Grant
  9. diesel4me
    Jul 24, 2003
    17,537
    922
    Massachussetts
    6000 lb "lifting arm" sounds interesting!...
    I bet the 6000 lb "Lifting Arm" is worth 500 by itself,if its got a winch or hydraulic cylinder on it!~..three tons is a lot,it cant be one of those cheap harbour frieght china hoists--might just be an"arm" with a 3 ton chain falls on it!...
    I dont know about the axles,only way to be sure is to look at them...about any motor from a 292 six to a 454 could be in a C30 truck...but if it did have a Dana 60 and a 454,I doubt it would be for sale so cheap,especially with that "arm" included in the deal--you never know though!.. :crazy:
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I guess I could give them a call tomorrow and find out if its 4x4 and check what engine is it. I guess comparing a d44 and d60 is easy, the 60 will be much larger? I will search a bit..
    p..s what transfercase would it have, a 205?
  11. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    'nother question,
    what cab configurations were availble in that year?
    I hate phones so I am getting itchy about calling...ill wait to tomorrow :doah:
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    Steve, do yourself a favor and pass on it no matter what it is. if you do buy it, you're going to fall into the same trap as i did. building a truck that's too big for your driving ability. that can get your hurt or killed in a hurry.
  13. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    beater,
    I was more along the lines of wanting it for a tow rig, I want a trailer, and we are selling the furd tow rig soon. just thought I'd call, 750 is good even if it has a d60... 454, etc
  14. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    but you are right, I shouldn't build the Jimmy too big until I am a good driver. I get my head in the gutter sometimes, thanks. :)
  15. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    make sure it has a 60 before you buy, they could of already swapped a 10blt or d44 in it, and that could be why its so cheap.
  16. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    What year did they come out with a 6.2 deisel? Later than 77 right?
  17. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    750 cool
    id snag it if i could
    take 650 in one pocket and show him it, see if he takes it
    he should
    maybe even just 600
    if no one has been biting really,
    you can tell just by talking to them, whether they will take a little less and if they just want it gone more than anything else
    never know.
    but that with the lifting arm and all damn id love to find one of those arms.,
    thats impossible here
    i only know of two trucks with a lifting arm on them,
    rare as hell.
    good luck
  18. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    1982 was the first year for the 6.2L diesel...
  19. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    so its going to be any size of gas engine? hmm... :doah:
  20. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    ah darn it was sold. now im wondering if they were trying to get rid of a good truck, or if it was just a beater...
    oh well...more deals will come hopefully!
