'77 3/4 Ton. What gear is in there?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chvyhs, Feb 8, 2002.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    \'77 3/4 Ton. What gear is in there?
    I have a chance to get a FF rear but I don't think the guy will let me pull the rear cover off to check gear ratio. What gear do you think came in it? It's a 1977 3/4 ton pickup with a 454, T400, and a 14Bolt FF. Thanks.
    <a target="_blank" href=http://community.webshots.com/user/chvyhs>WebShot Pics</a>
    It's a wheelbase thing, you wouldn't understand.
  2. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    Re: \'77 3/4 Ton. What gear is in there?
    i think the two ratios for the 1 tons were 4.10s and 4.56s...unless someone changed it thats what it should have...
    Later
    Just tap it in...tappity tap tap...
  3. speed_deed
    speed_deed 1/2 ton status
    Jun 15, 2001
    947
    Valley Center KS
    Look at the guy in the eyes and say "Well if i could get in there and it was the right ratio, It'd be sold! I just want to see if its in good condition"
    '85 k-5 gmc jimmy 4x4 sierra classic. '84 k-5 gmc jimmy sierra. '70 cuda 440 6 pack executive edition shaker hood, steering column shift.
  4. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    He won't let you pull the cover off? How the heck are you supposed to know what kind of condition it's in?
    the 14FF I got was from a '78 3/4 ton and it had 4.10's. I think that's the most common gear ratio in those.
    <font color=green>Can't sleep...the clown will get me</font color=green>
    <a target="_blank" href=http://www.bluefox.tv/~lara>My Wonderful Site</a>
  5. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    they only put 4.56 in a few 1 tons...
    the towingpackage had 4.10's the bonanza had 3.73's... the high sierra had 3.73's...
    it probably has 3.73's unless it's it's a trailering special...
    99 % on that
    -Aaron
  6. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    my 78 3/4 ton came with 4.56
    If the rear is still in the truck and the front is there. .. check to see if the tag is still on the front rear....
    geez that front rear stuff would confuse those low riders....
    1978 Chevy 3/4 - 14" leafs -dana 44w/4.56's -14 bolt corp w/4.56's on 40x17x16.5 Ground Hawgs on 16.5x12 steel rims-NP205&SMC465
  7. reddog64
    Nov 9, 2000
    3,325
    hey rootbreaker... in your glovebox does it show the axle code? it should of been a special order at the time... could you check for me. I'm curious...
    Thanks!
  8. RootBreaker
    Nov 29, 2001
    5,117
    173
    I'd love to but when I bought the truck it was rusted to like nothing.. so I switched cabs... then I went to a stick and swapped again... ( taller hump around tranny )
    sorry...
  9. chvyhs
    Feb 12, 2001
    1,469
    What code gives the axle gear ratio? Where's it at?
  10. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    my 77 3/4ton has 4.10s as do most of them. if he wont let you pull the cover (which he should) then you could count how many times the yoke turns to make the "wheel" turn one complete revolution.. helps to have two people because both "wheels" have to spin at the exact same speed...
    mike
  11. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Bottom line.....If he won't let you pull the cover......DON"T BUY IT with that said, once you do pull the cover, just count the pinion gear teeth and the ring gear teeth and divide them to get the ratio. Easiest and most accurate way of doing it. If the guy won't let you pull the cover he's got to be hiding something. It be like buying a used car without even starting it or opening the hood.
    <font color=red>COME ON RICHARD...GO PULL THAT COVER OFF AND TELL US WHAT IT'S GOT!!!</font color=red>[​IMG]
    BE <font color=blue>AMERICAN</font color=blue> BUY <font color=blue>AMERICAN</font color=blue>!!!!
    <a target="_blank" href=http://community.webshots.com/user/geltyone>Webshots Pics.</a>
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    Everybody hit the nail on the head here. If the guy won't let you pull the cover to inspect it, WALK AWAY!!! Something sounds very fishy if someone won't let you do a simple task like this.
    If you still insist on buying the truck, put it in writing that if you buy it and pull the cover off AFTER you get it home, and find something wrong with what you were looking for, the seller MUST pay or correct the mistake. [​IMG]
    See what he says after you tell him that. More likely than not, he will go ahead and let you pull the cover off. This is, only if he does not have anything to hide. [​IMG]
    <font color=red>Only real men drive K30's!!!</font color=red> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  13. speed_deed
    Jun 15, 2001
    947
    Valley Center KS
    I bought my 84 k5 with out opening the hood.
  14. chvyhs
    Feb 12, 2001
    1,469
    He doesn't want to start parting it out, he wants it all gone at once. 3 of us are going in on the entire truck. My bill is $50 and I haul it on my trailer. I work with the guy that owns it and the only problem is in the engine. I'm 99% sure the rear is fine. It's a '77 3/4 ton with a 454 (blown head gasket?) for $500.
