77 4 core radiator in 83 k5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by down4thakrown, Jul 27, 2004.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i got a 77 4 core and i wanted to know if it would fit in my 83 k5. I know the top part that holds it in place doesn't fit. but would the radiator fit??? If so does anyone have one?? /forums/images/graemlins/1zhelp.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the radiator in my 83 (2 core) fit in my friends 77 blazer perfect. the one in my 83 was the tall style also. so id say yep. for the 4 core you would need the 4 core brackets.
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    The shroud will be different. Be sure to use the shroud for the 4 core rad.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yu need to go retrieve your tape measure
    measure radiators overall height of tanks at the seams, and also measure width form seam to seam centers, these measurements will tell you what will fit what, ignore anyone who says they are the same even two and three core ones, i have run across about anything you can run across as far as variety of heights and widths of radiators from 67-87, its more interesting that you would think, for sure,
    there were several widths and heights depending on drivetrain ordered and HVAC system ordered and all kinds of other factors,
    shrouds changed in 81 anyways regardless of any thing at all.
    4 core is unique shroud and mounts, can be a PIA to convert without a 4 core parts rig especialyl 81-up
    if you need a factory 73-80 four core rad top panel then lemme know i have some of them still, and i have 67-72 ones too, no 81-up though, when i put a 4 core in an 81up i just modify the bvrackets with tin snips and a hammer and a carpenters knife, works fine
    if you want details then lemme know and ill explain
    the last 82 305 th350 truck i put a four core into i used a 74 C20 454 th400 one and it worked perfectly.
    '67-72 used smaller radiators, those trucks didnt use as big of radiators
    alot of the 77-79 trucks with 350 and smaller engines used radiator that was waaaaaaaaay low, the bracket panel was mounted down on front side of the radiator support well below the top surface of the rad support, even with a 350 yes and even in 3/4 4x4's
    i dont know why GM did this, maybe they ran out of larger radiators, 77-79 was mass production group years it seems, but they also used shorter 52" rear springs too under 3/4 tons those years alot,
    good luck
  5. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    well i ended up just taking the radiator out and trying to put it in and it looks like its goin to fit /forums/images/graemlins/peace.gif /forums/images/graemlins/woot.gif
    thx for the help fellas
  6. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
    I have that very radiator in my 84... I changed out the top brackets and no problems getting it to fit /forums/images/graemlins/thumb.gif
    its big and it does the job /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
