77-87 and 88-91 different lifts?
Discussion in 'The Garage' started by broncoman6524, Aug 12, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    MY buddys got a rolled k5 that im thinking about pulling the lift nad tires off of for my truck. Its an 88-91 k5. i was looking on roughcountrys web site to figure out just how much lift it has and it says that the 88-91 is diff than the 77-87 use diff lifts? is it true? ive got an 84 what would it take to make this lift work?
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Lift will be 73-87 for trucks but 73-91 for blazers, suburbans and crew cabs.
  3. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    oh thank god! i almost started crying...heres the deal $200ish includes front and rear springs (front maybe not usabe) pitman arm shocks brake lines. 335x12.5x15 x-terrains and wheels (one is cracked:eek1: ) and possibly a rear end (10b) with gears and a locker.:D im realy glad that the lifts are the same...hehe
  4. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    only problem you may run into is the difference in spring eye size for the rear eye on the front springs. I believe they were 7/16" in the pre 87s and the 87-91s were 9/16.
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    You are correct, but that is easily fixed.
  6. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    would that be fixed by like drilling a 9/16 hole in the spring hangers? bc that wouldnt be that hard or would it comprimise the strenght?
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    You would drill the shackles to 9/16" and use a 9/16" bolt instead of the 7/16" bolt.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    or you could just buy new bushings that are correct for your truck, they should fit right into the springs.
  9. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    I took the lift on my 87 off of a 76. Bolted up just fine. But little did I know, the springs and shocks were trash. Now I'm in the market for 4 new 4" lift springs, but can't afford brand new ones.
