'77 heads: Ok on unleaded?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Steve_87K5, Jan 15, 2001.
  1. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    \'77 heads: Ok on unleaded?
    Am taking some '77 heads in for a valve job. Are these OK as-is for unleaded fuel, or should I have hard seats installed?
    Thanks.
    SteveB
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Re: \'77 heads: Ok on unleaded?
    Those '77 heads (and any head made after 1975) should have the induction hardened seats which means you WILL NOT need hardened seats installed. I kinda don't like when a head is machined for seats, as the seats can come out and ruin your engine if you overheat it. I haven't had any problem with the induction hardened seats. The later model heads are even better, as they have the super duty exhaust valves too. Good luck.
    ken
  3. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    yeah theyll be alright. just for info.......the reason you should have hardened seats with unleaded is because in the old days lead in the fuel was kind of a lubricant. it also softened the impact of the valve closing. that way it didnt matter as much to have the seat a harder metal.
    Knife.
    knife.coloradok5.com
    <P ID="edit"><FONT SIZE=-1>Edited by nyyef on 01/15/01 10:55 AM (server time).</FONT></P>
  4. Steve_87K5
    May 26, 2000
    521
    central NC
    OK. Off they go to the machine shop. Was quoted $80 plus parts, and more if guides
    are needed. Thanks for the help!
    SteveB
