77 K5 Rear Axle Seals
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Overdrive, Jun 30, 2000.
  1. Overdrive
    Overdrive Registered Member
    Feb 28, 2000
    93
    Gilbert, Arizona
    I just finished replacing the rear leafs & blocks with new 4" springs. I noticed the entire right rear drum backing plate and rim (back side) were covered in what appears to be axle oil. I first thought it was a leaking wheel cylinder but the brake fuid in the res. looks ok. I need to first clean-up the goo but it looks like a blown axle seal. Anyone messed with replacing these? I know the innerworking of the 12 bolt and have read several articles through-out the years on gear installs. I am wondering how difficult it is to pull the axle and replace the seal. I think I just need to remove the diff cover, unbold and remove the center pin (I think that is what it is called), push in on the axle and remove the c-clip. Am I even close? I plan on checking the bearings and replacing the oil soaked brake shoes (I will do both sides). Thanks for any assistance!
    Overdrive
    P.S. The rear springs are fantastic!!! Much better than the 23 year-old stock springs with lift blocks. The ride is 100 times better (Firm yet not harsh).
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    You are correct on the procedure. Replace the axle bearings while you have them out. You will need a slide hammer or other special tool to get the bearings out.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  3. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    Im sure you know this already but its best to do both sides inside of one and doing that procedure twice. Just dont break the small bolt in the center pin, I did that and was in a world of anger to get it out, it wasnt fun. Oh its was a 10 bolt not 12 but its still a pain to get that thing out.
    J.D.
    88 Gmc Jimmy
