'77 or '98 block????????
Discussion in 'The Garage' started by K5Glazier, Jan 22, 2004.
  1. K5Glazier
    K5Glazier 1/2 ton status
    May 29, 2003
    220
    Chandler, Az.
    \'77 or \'98 block????????
    When I decide to do the stroker thing, which block should I use? Both are 4 bolt mains and neither of them have been bored. I've been told that the older blocks were made stronger, but I also believe in the new technology of making things better. What do you all think? /forums/images/graemlins/ears.gif
    Thanks in advance... /forums/images/graemlins/thumb.gif
    Joe
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Re: \'77 or \'98 block????????
    If you want a roller cam, go with the newer block.
    Otherwise it matters not much.
    Crappy castings can be had from either year....
  3. dyeager535
    26,982
    191
    Yeah I say go with the newer block for roller cam, just remember the flexplate or flywheel will be different.
    From what I've seen on my vortec heads, the castings are probably MUCH cleaner in the newer blocks, but the only real advantage to that being perhaps better oil drainback.
    I'm a big fan of roller cams, and factory roller cam blocks are IMO your best bet to go "cheap" roller.
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Go for the new block. Cheap roller cam (as already mentioned. Probably much less clearancing necessary for the stroker crank - my buddy's crank fit without fuss... although he did grind extra just to be extra safe.
    One-piece rear main seal is a very nice benefit. /forums/images/graemlins/wink.gif
