77 wiring diagram...
Discussion in 'The Garage' started by ryoken, Oct 15, 2006.
  1. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    Anyone have a diagram on file for the underdash on a 77? or close to that? maybe pre 80...
    I have the factory one for my 87 which has been a godsend, but I'm incorporating some 77 parts in my build... Mainly interested in the column turn/hazard plug at the base of the column and how it ties in and feeds thru the junction/fuse block, hazard/turn flasher, etc. Consists of 10 wires.. Horn is black, etc...
    Ignition switch plug to fuse panel would be handy too, but not as needed.. I'm trying to avoid a couple hrs dorking around with a meter and continuity tests...
    As always any help appreciated... :D
  2. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
  3. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    Actually, yeah, that does help...
    Muchos Gracias...
  4. diesel4me
    Jul 24, 2003
    17,543
    936
    Massachussetts
    I have one...
    Turn signal switch
    horn = black
    left front lamp = light blue
    rt front lamp = dark blue
    hazard warnings = brown
    flasher = purple
    left rear lamp = yellow
    right rear lamp = dark green
    stoplight switch = white
    My diagram shows only 8 wires! (?)...sorry,I have no means of posting a picture of it..probably couldn't read it if I did-I had to use a magnifying glass just to read the color codes..:doah:
    Ignition switch has 8 wires too,
    orange,
    purple/white
    brown/white(gauges only)
    dark green (not used with gauges)
    pink
    red(2)
    brown
    tan/white
    if you need more info let me know--not sure if I can read the printing on the ignition switch section of my wiring diagram,but I'll try to help if I can...:crazy:
  5. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    Awesome Bob, that just confirmed what I had worked out....
    Those last 2 where a pink and black seperate from the other 8, they ran to some tabs that did nothing on the t/signal, so I'm not worried about em...
    Thanks again...
