78 1ton master cylinder ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigMac, Oct 12, 2002.
  1. BigMac
    BigMac 1/2 ton status
    May 27, 2002
    397
    Fremont, CA
    OK, I picked up a 78 1 ton master cylinder... Im looking at the resiviors and the front one is smaller than the back one, big time. Is the front res for the rear brakes?
    On my half ton the front is the front....
    any help before I tear my old one off s greatly apreciated...
    /forums/images/graemlins/truck.gifthis kinda looks like my truck
  2. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    i discovered the same problem when i put a 3/4 ton Master in my truck, but after actually reading my factory manual, i found out that yes on 3/4 and one ton masters, the front is the back and the back is the front, just bend the lines a little and hooker' up. /forums/images/graemlins/cool.gif
  3. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    the bigger one is usually the for calipers...they take a lot more fluid to use. pict ure the piston in the caliper, then picture the size of the wheel cylinders...then it makes sense
    RYan
  4. BigMac
    May 27, 2002
    397
    Fremont, CA
    Just as I thought... Im fabbing new hard lines right now that go from the master to the praportioning valve...
    none of the damn fittings are interchangeable...
  5. BigMac
    May 27, 2002
    397
    Fremont, CA
    well damn... it seems I need a new booster to get this dang thing on too.... the shafts are different lengths.
