78 3/4 ton Master Cylinder and Proportioning valve question
Discussion in 'The Garage' started by Yukon Jack, Jan 8, 2007.
  1. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I have removed a manual brake master from my 1970 K5 and have installed a master cylinder, booster and proportioning valve from a 1978 3/4 ton.
    I removed the donor parts quite some time ago and I don't recall which reservoir is supposed to feed the front as opposed to the rear.
    I currently have it hooked up with the front reservoir going to the proportioning valve to feed the front brake lines.
    Can someone with a 78'ish 3/4 ton take a look and see which reservoir feeds your front brakes? I believe your proportioning valve should be on a crossmember about below the engine fan.
    Here is how mine is presently ran
    Thanks :saweet:
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Normally the rear res feeds the front brakes. This isn't always true, but it is at least 90% true.
  3. goldwing2000
    goldwing2000 Guest
    If one reservoir is larger, that one will feed the front. If they're both the same size, it doesn't much matter. The piston is the same size all the way through, disc brakes just require a larger volume of fluid over time due to the way a caliper "self-adjusts".
  4. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Thank you!
