78-79 4x4 ferd trucks. what can i use on my chevy
Discussion in 'The Garage' started by 84CUCV, Aug 1, 2005.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Friends father is junking a 78 f250 and a 79 f350 4x4 trucks. Anything good i can get off it for my M1009??
    as always thanks guys
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    If it has a high pinion 60 then take it and the t-case
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Snag the front axles! I think that the F250 will have either a HP Dana 44 or 60, depending on factory options. The F350 should be a HP 60. Both are drivers side diff, which is the hot ticket for folks doing late model GM solid axle swaps. :cool1:
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK wow didnt know that thx
  5. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Get the t-case for the front output...too. ;)
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Snag the whole drivetrain from the F350. The axles will highly likely be D60HP front and D70 rear along with the NP205, you can swap all that into your GM and go as low as 7.17 gear ratios in the axles. :bow: :bow: :bow:
  7. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    the 60 fronts are bringing around 900-1100 on ebay alone. if divorced tcase thay bring 200 range. and if going dubler you can use the front axle under your truck and get the kit and use the 205 case with the dobler and not change the input as ford is 31 spline . good luck.
  8. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    This could work out well.... Sweet What does a 460 go for? any idea? thx
  9. nerraw117
    nerraw117 1/2 ton status
    Jan 5, 2005
    788
    charlotte, NC
    quite a bit, a 460 swap is a highly regarded engine for bronco's wanting to do that swap, which alot of them like to do.
  10. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    thx for the replys mike
  11. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    around us I wouldn't expect to sell the 60 for 900-1100. I sold a Chevy one for $650 and I sat on it for a while. Still I only paid about $300 for it and put nothing but time into it, so basically doubled my money for nothing.
  12. cow killer
    cow killer Registered Member
    Oct 21, 2003
    54
    sellersville pa
    ahem.... your welcome. lol
    hall, i got 200 on mine.
  13. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Did you tell me about my Chevy one? Its been so long I can't remember. I only paid like $250 for it at Geese's(the chick gave me a deal and didn't realize it was a 60). Of course you hooked me up with my High Pinion, now hook yourself up wtih a new one :D
  14. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Trying to get the ford facts straight here...
    both will have either 300 L6, 351, or 400 motors, unless someone did some swappin'.
    C6 or NP435 married to NP205.
    both will have FFD60 rear axles.
    the F350 will have a HPD60 frontend, provided no swapping occurred.
    F250 could go either way...check to see if it has smooth kingpin caps or castle nuts on top of the knuckle.
    awesome score and good luck!
