78 cab on 84 blazer frame?
Discussion in 'The Garage' started by bryguy00b, Mar 7, 2004.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    does this work? 78 pickup cab on a 84 k5 frame..not sure what years were bolt and and what not..
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    There's nothing to support the rear cab mounts on the Blazer frame. The Blazer frame is low-slung through the mid-section so you need to build some kind of mount tower or something.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    And it uses different bushings
  4. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    is that for this year? what if i put an 86 cab on it? ive heard all u have ot do is put the cross member in there that it needs for the rear mount and other than that it was bolt on..
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the bushings are different but just buy them for the year cab as the frame mounts ar the same. also for the rear cab mount, take the crossmember out of a truck and make some extentions to raise it up to reach teh cab /forums/images/graemlins/waytogo.gif
