78 Chevy Short Box Engine Mount Problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by merc359, Nov 26, 2005.
  1. merc359
    merc359 1/2 ton status
    Mar 25, 2005
    103
    Vancouver, BC. Canada
    He All,
    I have a ridiculous problem that has me scratching my head. I have a feeling I am missing something stupid and will be laughed off the forums, but I'll post anyways.
    I have a '78 ShortBox Chevy 4X4. Bought the truck in pieces: frame, cab, box, drive-train, etc... I am now assembling it. All diffs are in, frame is sand-blasted, POR-15 painted, and now I am bolting the engine, tranny, and transfer-case in.
    Here's the issue:
    The original motor mounts that bolt on the frame were all nasty and worn. I took them out, cleaned them up, painted them, and put the High Energy Suspension Polyurethane insterest into them. I put them all back together as I have done on countless other vehicles. I bolted the engine-side motor mount to the new motor and tried to lower it into the cradle.
    NO LUCK!
    The motor will NOT lower down enough to let me bolt it in. I tried turning the mounts, rotating the inserts, changing sides... Nothing works....No matter what I do the motor-side mount hits the frame-side mount on both sides equally and won't let me drop the engine down the last 2 inches I need in order to put a bolt through the whole mess.
    Now, the frame, frame mounts, and "clamshell" mounts (frame-side motor mount) are all original. The only part that is not from this exact truck is the engine-side engine mounts.
    Bottom Line Question: Are there different sizes of engine-side stock GM motor mounts? I am talking about the all-metal pieces that bolt with three bolts to the BLOCK. Are there variants of that piece that might affect the geometry of the engine? For example, are there 4x4 ones and 2wd ones? I can think of nothing else and the damn engine just sits too high.
    Any feedback or avenues to explore would be great. Thanks,
    Merc359
    (Rowan Smith)
  2. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    What is the engine your putting in? Maybe different than what the mounts were made for?
  3. merc359
    Mar 25, 2005
    103
    Engine Issues
    The engine was originally a 305. I took out the 350 and used the 305 mounts. Never had an issue until now.
  4. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    I'm not sure about trucks...but I know that the 80's camaro and 80's monte G bodys had different metal pieces that bolted to the block. So, probably, there might be a variance between truck and car as well.
    Blake
  5. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    just a idea. do you have the engine crossmember in the frame ? or have you had it out or swaped to a diffrent one. i have mine out for a new one and went to pop motor in and needed to spread the frame with my high lift jack to get it to pop in.
  6. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Yes there are different block mounts for 2x4 and 4x4 applications. the 4x4 block mounts are taller.
    time to hit the junkyard i guess.
  7. sweetk30
    Nov 1, 2004
    25,552
    547
    ah correct me if i am wrong but dont thay bolt to the 2x4 crossmember unit?
  8. merc359
    Mar 25, 2005
    103
    Mount Height
    Hi,
    Just to clear up a couple of issues:
    1. I have never had the engine cross-member out of the frame.
    2. I have never taken out the frame piece that the engine mount bolts to.
    I gathered from one of your posts that the 4x4 mounts are taller. That would make perfect sense given the nature of the problem I am having. With the mounts I have, it seems like the engine needs to come down and sit lower in the cross member in order for me to get a bolt through, but the damned block-side mount binds.
    If it (the block-side mount) was taller, then the mounts would likely line up properly as I wouldn't have to lower it down as far. This is all contingent on me having the geometry of the beast straight in my head.... I'll go check the frame next time I am at my shop. I should have tons of 2x4 and 4x4 mounts kicking around.
    Thanks for your input.
    Rowan
    Merc359
  9. sweetk30
    Nov 1, 2004
    25,552
    547
    some times the stock rubbers slide down in the shells and need to be moved around a bit to line up.
    good luck buddy.:D
