78 K20 Ignition??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by black'burb, Dec 2, 2006.
  1. black'burb
    black'burb 1/2 ton status
    Mar 11, 2005
    182
    Northeast WA
    Looking to bypass ignition system with push button start. What's best/easiest way to set up???
  2. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    Do you want a toggle for ignition and a button for start, or keep using the key for ignition, and just a button for start? 2nd one is pretty simple. get a 12ga wire from the battery (fused) to the dash, push button, then run it down to the starter. Should be a purple wire down there, attach to that terminal, done.
  3. black'burb
    Mar 11, 2005
    182
    Northeast WA
    Yeah I was looking at doing the second one. Sounds simple enough, thanx
