78 K5 Motor problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Scott73, Jun 19, 2002.
  1. Scott73
    Scott73 Registered Member
    May 22, 2002
    38
    Electra, TX
    Just bought a 78 K5 Blazer for $800. The body is almost perfect with no rust, but the motor has no power. I'm going to put new plugs and wires on it tomorrow because I know its missing and then try the timing and the carb. When you give it the gas it acts like it wants to die and then barely goes. It slowly got up to speed and drove home at 70 on the highway, but couldn't maintain the speed up hills. any ideas?
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    what engine/gears/tires size/tranny?
  3. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    ya can try the fuel pump. that might be out. 800 is a good deal for the shape of the body. hope this helps. later
  4. BlazingItaly
    BlazingItaly Registered Member
    Apr 7, 2000
    35
    Milan Italy
    Try a compression test and check fuel filter.
    Hope this help
    Luca
