78 parts on an 84 ???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ellero, Jul 31, 2006.
  1. ellero
    ellero Registered Member
    Jan 25, 2004
    66
    Covington, Georgia
    I just bought a transmission and transfer case from a 1978 K5 to put into my 1984. When I look at the transfer cases the one from the 78 is much larger. I have not yet removed the transmsission. Should these interchange? I also notice that the 78 T-case is NOT a slip yolk. Any clue what kind ot T-case it is? Thanks
    John
  2. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    There will be a length difference you should have a 700 r4 and a 208 or a sm 465 and a 208. The trans from the 78, if the trans is a turbo 350 will be a 203 (very big heavy etc full time case) if it is a turbo 400 it could be either a 203 or a 205 ( the 205 combo is very desirable) if it is a sm 465 it will be either a 205 or 203 (the 203 case to the 465 is somewhat rare. There are tags on the back of the 208,205 and 203 to identify them. If it is a auto you will have to look at the tranny pan to see what it is. Chevys are really nice in the fact that alot of stuff can interchange so I would say yes the 78 stuff will bolt up and probably work but you may need to change other minor things
  3. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    The 78 if it's an auto will be a TH350/203 and since you live in California you cannot put that combo into your rig if you need to pass Cali emissions. The reason is because California considers the tranny as part of the emissions crap since there is an service engine soon light that would come on because of a lack of TCC. If you have a new chip burned that eliminated the TCC then you might get away with it. You will have to do driveshaft mods and also find the 203 shifter as well.
  4. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    does the '84 even have a computer?
  5. maynardogle
    maynardogle 1/2 ton status
    Mar 7, 2005
    159
    Orange County, CA
    Yep...84s have a computer...except the 48 state diesel.
