'78 Quadrajet choke
Discussion in 'The Garage' started by Ben B., Aug 25, 2006.
  1. Ben B.
    Ben B. 1/2 ton status
    Sep 1, 2005
    352
    Central PA
    My choke's always open..I think the spring that pulls it closed is bad but i really don't know much about that stuff as of now. Any ideas?
  2. Ben B.
    Sep 1, 2005
    352
    Central PA
  3. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    first I'd check and see if there's always power going to the coil. if so change it to a switched 12v source. then after that your guess is as good as mine.
  4. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    If it's the divorced choke style that operates off manifold heat the bi-metal coil may just be bad. Check to make sure the linkage is not binding and the adjustment is correct. If those two things are in good order your probably going to have to buy a new bi-metal coil. You can get them at Summit as a last resource but they are pricey. Try to find one at the local NAPA or other parts store.
  5. dyeager535
    26,980
    If it doesn't snap shut when the engine is cold, then I'd check to make sure it's adjusted right.
    The spring should be under tension when the engine cools off, (in the morning, not after sitting for an hour or two) kicking the throttle wide open should snap it shut.
