78 questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudslinger6, Jan 17, 2005.
  1. mudslinger6
    mudslinger6 1/2 ton status
    Aug 1, 2004
    125
    live in ct by the mass line
    a 78 3/4 ton 4x4 with all time 4x4 tranny would that have a dana 44 up front???and whats the stock gears in that???
  2. cyclone
    cyclone 1/2 ton status
    Oct 11, 2004
    243
    Sonoma, CA
    k20
    My 79 K20, Camper Special 8400GVW has a 10blt front, 14blt rear, 4.10 ratio
  3. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    78 questions, that's a lot!
    Check what the front axle looks likes, perfectly round differential, 10 bolt, otherwise D44
    Check the glovebox sticker for gears
  4. k5redneck
    k5redneck 1/2 ton status
    Jun 24, 2004
    1,000
    mesa AZ
    78 was the last year for the dana 44 up front. the most common gear is a 4:10.
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i had a 78 blazer that had a 10 bolt. from what i have found it can be either 10b or d44 for 78 and 79. in a 3/4 ton i would guess 4.10
  6. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Dana 44
    Corp 10
  7. speedyvision917
    speedyvision917 1/2 ton status
    May 5, 2004
    472
    CT
    also, does anyone know about all wheel drive for that year?
  8. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If the front axle was Full time 4wd, then it would have full time lockouts. And the 203 tcase would of been fulltime. The full time lockouts look like this:
    Top pic is off a 3/4ton and the bottom pic is off a 1/2ton
  9. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    A Dana 44 was available up until the very early eighty's - although most came with a 10 bolt front since 1977 .
    Tom
  10. mudslinger6
    Aug 1, 2004
    125
    thanks all for the help if i run into ne more questions ill post them thanks shaun
