78 - Wiring question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MKeen, Dec 10, 2001.
  1. MKeen
    MKeen Registered Member
    Jun 20, 2001
    20
    Tulsa, OK
    Fast question to see if I am missing anything. When I turn my blinkers on the fuse blows.
    All bulbs are good
    Hazards work good all 4 flash
    Turn signal relay has been replaced.
    I am leaning toward a bad turn signal switch in the steering column. What you all think.
  2. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    If your 4 ways work that pretty much says that your blinker wires are good. The only change in wiring is the turn signal switch. Did you check for pinched wires where the switch wiring comes out at the bottom of the steering column?? If those are good then I agree that the switch is most likely bad. I think that I paid about $20 from GM for the last one that I bought.
