79 Blazer, 4-inch, need info on u-joints
Discussion in 'The Garage' started by 79cheyenneblazer, Jun 14, 2005.
  1. 79cheyenneblazer
    79cheyenneblazer Registered Member
    Jul 21, 2002
    68
    Jasper,Indiana
    :confused: I have a 79 k-5, 4-inch lift with 33's, I put a 2-degree shim on the new re-arched springs and I am still having problems with u-joints. I get a loby vibration when I take off from a stop and the u-joints have in the past been eatting up needle bearings. I put the napa heavy duty u-joints in and they do the same. I have the original drive train still in it, 350/350/np203, so I am asking since there are a lot of you out there with lifts, what do you do about this? Which u-joint do you recommend? I was told by someone that I should put traction bars on the rearend to stop the vibration on take offs, would that help? I just need info on this since I am driving the blazer everyday. Thanks for any help you might have.
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Well first I got a "1 ton" driveshaft with 1350 U-Joints. Before, my U-joints may last a month if I babied it. After the driveshaft they lasted a few months. What really cured my vibrations was a CV driveshaft with 1350 joints. You will need to get a new pinion yoke for the rear but the CV has never failed me. Even when my U-bolts loosened and my axle shifted it still held up fine. Personally I think CV driveshafts are the only way to go!!
    :cool1:
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    The ujoint angles at the TC and rear end need to be the same. By adding the shims it is now probably worse than before. If you cannot get equal u-joint angles, then a CV shaft is a good choice for a fix, but it costs $$$$$
  4. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I have an '86 lifted 4". The first thing I did after I drove it around the block was drop the transfer case 1". No vibes, and ujoint's stay in as long as I let them.
    John
  5. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    Have a '90 K5 w/4" lift. Mine vibrated like crazy. I bought a new shaft w/ CV joint up front. No vibration at all now.
  6. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Hmmm. I dropped my t-case and still had vibes.
  7. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    4in tc, 1in tcase drop, no probs
  8. 79cheyenneblazer
    Jul 21, 2002
    68
    Jasper,Indiana
    Yeah I thought about a CV joint, would it be possible to stick a cv joint into the stock driveshaft, by a driveshaft shop of course, or would I have to buy a whole new driveshaft?
  9. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    You could probably use the stock driveshaft as a core, and buy a new CV driveshaft. Not sure if someone can modify the stock one easily, or if a new one is easier. Its probably best to shop around, for the best deal. If money is not a big issue, High Angle Driveline makes (in my opinion) the best, high-end driveshafts available. Still, a competent shop should be able to put something together that would work for less $$. http://www.highangledriveline.com/1350_constant_velocity_joint.htm
  10. ntx78k5
    ntx78k5 1/2 ton status
    Oct 22, 2004
    166
    Home of the Rangers
    78 W 4" lift, 1" drop kit for the transfer case and all is well.
