79 Burb to 72 Blazer front axel swap?
Discussion in 'The Garage' started by gstuck3, Mar 18, 2005.
  1. gstuck3
    gstuck3 Registered Member
    Mar 15, 2005
    51
    Twentynine Palms, CA
    Will the front axel from a 1/2 ton 79 Suburban fit a 72 Blazer easily?
    Should I just have the original axel rebuilt? How much would this cost?
    I am looking to buy the Blazer and the guy said the front carrier is cracked and it needs head work. I have a 79 Burb for a donor vehicle if needed. The Burb is my daily driver right now but plan on getting rid of it anyways and am trying to find any reason I can to get the Blazer. If the axel can swap I should be good to go cause I have a good engine to put in it. Also, do they make a/c compressor brackets for now accessory hole heads? And how do you do that np205/203 doubler thing? Thanks.
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Yes! It is a direct bolt in. Just make sure the axle ratios are the same.
    I have the front axle from a '77 K20 in my '71 Burb.:D :D
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yes, fits like a glove. I had one out of a 80's truck under mine for a while.
  4. gstuck3
    Mar 15, 2005
    51
    The Burb has 3.73's and I'm sure the Blazer has the same. What could cause a carrier to crack?
