79 chevy truck 1 ton 4x4
Discussion in 'The Garage' started by edlavarreda, Sep 13, 2003.
  1. edlavarreda
    edlavarreda Registered Member
    Nov 26, 2002
    56
    do all 1 tons come with a dana 60 owner wants $100.00 for front axle is it my lucky day?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes all one tons come with a dana 60 front but make sure it hasn't been switched out and is truly a dana 60 first /forums/images/graemlins/thumb.gif
  3. edlavarreda
    Nov 26, 2002
    56
    IM CROSSING MY FINGERS THANKS
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    big score if the truck is really a k30 or k3500 ! look on lower RH corner fron side of diff housing for a raised `44' or `60' is pretty big, should be able to see it immediately when you look close.
    self explanatory
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    If he doesn't have to scrape it good first /forums/images/graemlins/rotfl.gif
  6. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    wouldent it even be easer to just look at the passenger side ubolts? If there 2 it would be a 44 or 10bolt if theres 1 and some studs then ita a 60 right?
  7. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Yep,Also look at the steering arm.If it a square pattern with four bolts it's a 60 if only Three it's a 44..........
  8. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Unless some devious person put a Dodge D44 under it.
  9. edlavarreda
    Nov 26, 2002
    56
    I went to look at it today but some bastard must to swaped it for a D44 oh well I have to keep looking
  10. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    well that sucks /forums/images/graemlins/frown.gif
  11. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    100 for an 8 lug 44 is still cheap /forums/images/graemlins/grin.gif
  12. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Try Cleveland truck parts.Give them a call they usally have dually 60's there.around 600.00. 216-961-6300. you will have to change the hubs to single wheel hubs.Dynatrac has kits to do this.............good luck
  13. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Which puts you right back at $1000.
  14. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    yep,which is about the going rate for a 60.
  15. edlavarreda
    Nov 26, 2002
    56
    patience always pays off or should i go for the rockwells my friend has a set laying in his back yard he wants $500.00 for them will it be too much trouble to make them work on the blazer will they be street legal /forums/images/graemlins/confused.gif
  16. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    it will be a lot of work and you won't want to daily drive it. Unless your planning on like 44s or bigger rockwells aren't for you. You need big lift and big tires and I know it would be hard for me to make them street legal cause tires can't stick past the fenders in PA.
  17. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    only problem with those you are limited as far as gear ratios and stuff like that.most of them have a 7.17 ratio gears.
  18. thatK30guy
    Jan 12, 2001
    32,076
    55
    2.5 ton Rockwells have 6.72 gear ration.
    5 ton Rockwells have 2 choices of ratios to choose from. One is 6-something and the other is 10-something.
  19. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Hey k30guy,Thanks for the info.I was mis-informed on these.still though 6.72 is steep.........Thanks
  20. edlavarreda
    Nov 26, 2002
    56
    that answered my questions you guys are the k5 gurus thank you for taking your time /forums/images/graemlins/grin.gif
